singhsaju Fri, 10/03/2008 - 08:59
  • Silver, 250 points or more
Do not use NAT 0 but allow the traffic to be PAT'ed and create Crypto ACL with Pate'd address as source .
For Example :If 172.16.0.0/16 is remote private network and X.X.X.X is the PIX 's outside interface IP. The remote side will have Crypto ACL as mirror image of the access -list 101.
interface Ethernet0
nameif outside
security-level 0
ip address X.X.X.X 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
access-list 101 extended permit ip host X.X.X.X 172.16.0.0 255.255.0.0
crypto ipsec transform-set my-set esp-aes-256 esp-sha-hmac
crypto map mymap 20 match address 101
crypto map mymap 20 set peer 172.30.1.1
crypto map mymap 20 set transform-set my-set
crypto map mymap interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption aes-256
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
tunnel-group 172.30.1.1 type ipsec-l2l
tunnel-group 172.30.1.1 ipsec-attributes
pre-shared-key *
Saju
Pls rate helpful posts
