Can't ping the inside address of the ASA
Answered Question
Oct 3rd, 2008
Guys -
Below is a config of my ASA 5505. The ASA has a site-2-site tunnel with the corporate. From the coporate, I am able to ping every host behind the ASA 5505 but not the inside address of the ASA. And therefore I am also not able to ssh to the inside address.
Any ideas??
ASA Version 7.2(4)
hostname Site-ASA
domain-name abc.local
enable password xxx
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address XXX.XXX.XXX.XXX
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
domain-name aem.local
same-security-traffic permit intra-interface
access-list AEM2FJDC extended permit ip
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list AEM2FJDC
nat (inside) 1
route outside XXX.XXX.XXX.XXX 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
aaa authentication ssh console LOCAL
http server enable
http outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set 3desmd5 esp-3des esp-md5-hmac
crypto map VPNMAP 10 match address AEM2FJDC
crypto map VPNMAP 10 set peer XXX.XXX.XXX.XXX
crypto map VPNMAP 10 set transform-set 3desmd5
crypto map VPNMAP interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
telnet inside
telnet timeout 5
ssh inside
ssh inside
ssh inside
ssh outside
ssh timeout 5
console timeout 0
dhcpd dns
dhcpd wins
dhcpd lease 28800
dhcpd domain abc.local
dhcpd address inside
dhcpd enable inside
username admin password YgCxRI4lQ4ZKOS2I encrypted
tunnel-group XXX.XXX.XXX.XXX type ipsec-l2l
tunnel-group XXX.XXX.XXX.XXX ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
service-policy global_policy global
prompt hostname context
: end
Correct Answer by ajagadee about 8 years 3 weeks ago
You need "management-access inside" configure on your ASA to access the inside interface through the IPSEC Tunnel.
Please refer the below URL for details:
** Please rate all helpful posts **
Overall Rating: 5 (2 ratings)
ray_stone Fri, 10/03/2008 - 11:54
Hi, May I know what is a use of Management access command and basically when it require to enable it?? Thanks
abinjola Sat, 10/04/2008 - 10:09
Generally, you cannot telnet,ping inside Interface from outside, however when you are coming over a VPN tunnel then you may require to telnet/ping/connect to inside interface, therefore management-access command ensures you are able to do so
