10-03-2008 09:10 AM - edited 03-06-2019 01:44 AM
Just wondered if anyone can offer some info on the key differences between the following cards - pros and cons etc.:
WS-SUP32-GE-3B
WS-SUP720-3B
One question is how does the following affect the communication performance between the supervisors and say a 48 port LAN Card.
Q. What are the backplane and forwarding speeds for Sup32?
A. Sup32 is a "classic" supervisor that connects to the 32-Gbps bus. The supervisor does not include and does not support a switch fabric. The forwarding performance is 15 Mpps.
Thanks for your help
Solved! Go to Solution.
10-03-2008 11:48 AM
Below are mentioned the key differences
1.One difference as you said is Sup720 can forward up to 400 Mpps whereas Sup32 at 15Mpps
This is huge difference in terms of throughput
So when complete 6500 chassis is filled with Rj-45 modules , and all ports are heavily utilized , Sup720's 400 Mpps will give better results than Sup32's 15 Mpps
2.Other key difference is Distributed Cisco Experss Forwarding (DCEF)is possible in Sup720, but it is not in Sup32.DCEF gives capability to line cards or modules to populate the forwarding table with local copy on the module & make forwarding decisions on module itself locally , providing maximum performance & scalability
HTH...rate if helpful..
10-03-2008 03:01 PM
The biggest difference between the two cards is the sup720 provides a 720 Gbps switch fabric. (Prior to the sup32/sup720, there were separate switch fabric cards that could be used with the sup2.)
The sup32 only supports classic bus line cards. The sup720 supports classic bus line cards and both (old) CEF256 and (new) CEF720 fabric line cards.
The other difference is the sup720 supports either a 15 Mpps forwarding rate for classic bus cards, or up to 30 Mpps for fabric line cards. Also with the latter, some fabric line cards support distributed forwarding on the line card if a DFC is installed. Distributed forwarding performance varies on line cards between dCEF256 and dCEF720 (which I recall[?] as being, on the line card, 15 Mpps for the former and 48 Mpps for the latter).
Performance shouldn't be a real issue between line card and supervisor for either sup32 or sup720. More likely issues are data forwarding bandwidth and forwarding performance.
For classic bus line cards, the whole chassis shares the bandwidth (in concept, somewhat like an Ethernet hub where line cards are the "ports"). For fabric line cards, line cards might connect to 1 or 2 8 Gbps or 1 or 2 20 Gbps fabric connections (in concept somewhat like an Etherner switch where line cards are the "ports").
15 Mpps provides about 10 Gbps forwarding for 64 byte sized packets.
10-03-2008 11:48 AM
10-03-2008 04:01 PM
Satish,
Thanks for the reply and useful info. It was very helpful.
Many thanks
John
10-03-2008 03:01 PM
10-03-2008 04:03 PM
Joseph,
Thanks also for your reply and useful information. It will help me collate a good response to our customer.
Many thanks
John
Many thanks
John
