Zach Seils Fri, 10/03/2008 - 22:59
  • Cisco Employee,
The default interface MTU in WAAS is 1500. You can adjust it in interface configuration mode. A more preferred approach would be to adjust the TCP MSS for the optimized connections. By default, WAAS will use the lesser of the MSS advertised by the client/server and 1432. If you have a need to manually adjust the TCP MSS, you can use the command:
tfo tcp optimized-mss <512-1460>
Zach
