FTP upload issue
Oct 3rd, 2008
hi i have 2mb of DXX link connecting my site to site routers. The only traffic on the link is FTP, FTP is not working properly, i have 40 -60 kbps upload and 80-90kbps download speed. Any recommendation to improve upload speed.
rais Fri, 10/03/2008 - 11:20
you may adjust the TCP window-size of the hosts involved.
Thanks.
milan.kulik Fri, 10/03/2008 - 12:44
what is the distance between sites?
I had similar problem on a line between Europe and India.
The long distance caused FTP acknowledgement very slow.
I used an FTP client running several prallel sessions to speed-up the file transfer.
BR,
Milan
itdsmartnet Fri, 10/03/2008 - 13:33
Thanks for your reply, the distance between the two links is 600 km.
milan.kulik Sun, 10/05/2008 - 11:40
have you tested somehow you are really getting 2 Mbps on your line from your ISP?
BR,
Milan
itdsmartnet Sun, 10/05/2008 - 23:27
hi,
we are getting 2Mb that's why i am getting 230KBps. The only problem is of uploading.
