Configuring Probe on ACE
Answered Question
Oct 3rd, 2008
If I need to configure a request method probe for website www.abc.com, should the command be
request method head url /abc.com
OR
request method head url /www.abc.com
OR
request method head url www.abc.com
Regards.
Correct Answer by Syed Iftekhar Ahmed about 8 years 5 months ago
None of the above
www.abc.com is hostname not URL
If you want to probe home page url at www.abc.com the just use
and make sure that you configure
expect status 200 200
under probe definition.
Syed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Fri, 10/03/2008 - 10:25
  • Blue, 1500 points or more
None of the above
Syed
