H323 Gateway - 2821 FXS Question
Oct 3rd, 2008
I have a 2821 H323 gateway with a 2 port FXS card. I programmed an analog phone ext. that is working fine. My question is this - is there a way to have that analog ext. appear as a line appearance on a 7941 phone? I'm not that familar with dial peers so I didn't know if there was some way of doing this. I would like other people to be able to answer the call if not answered on the analog phone.
Thanks in advance for the help!
andres.pasten Fri, 10/03/2008 - 10:51
If the FXS is H.323 controlled it must be defined as a route pattern on the CCM to call that port. In that case, you can't use it as a line on an IP Phone.
If you control the FXS using SCCP or MGCP you can do that because you must define the line on the CCM.
Andres Pasten
Adexus S.A.
