Shortcut for this task?
Oct 3rd, 2008
I have a 3750 switch that has 4 subnets connected all to VLAN 1. My task is to create a VLAN for the servers, and all of our servers are on one subnet.
I can do:
sh arp | inc
to get the ip addresses with mac, but then I'd have to do a:
sh mac addr | in xxxx
for all of the ip addresses that I have. Is there a quicker way of getting the port assignment and ip address that was seen on that port?
Giuseppe Larosa Fri, 10/03/2008 - 12:53
Hello John,
my only suggestion is that you can use:
sh mac addr addr xxxx
for the second step
but you need to access both ARP and CAM tables to locate the devices.
Hope to help
johnlloyd_13 Sat, 10/04/2008 - 23:59
i just recently did this task on our network.
to get the ip addresses on the router:
show ip arp
to get the mac address and interface on the switch,
show mac-address-table dynamic
then try to compare these 2 tables to know where the assigned ip address and mac address of the device is located on each switch interfaces
