Using some timeslots in a pri-group
Oct 3rd, 2008
Hi. We had a R2 signaling configuration, in which we used ds0-groups to specify the use of only some timeslots, like this:
controller E1 1
framing NO-CRC4
ds0-group 2 timeslots 1-2 type r2-digital r2-compelled ani
ds0-group 3 timeslots 3-15,17-19 type r2-digital r2-compelled ani
ds0-group 4 timeslots 20-23,30-31 type r2-digital r2-compelled ani
cas-custom 2
We migrated to SS7 signaling (AS5400 with PGW). We used pri-groups and it's working OK. But now we need to specify the use of only some timeslots per customer (kinda like the R2 config above), but with pri-groups we can't do this. I think the solution will be using trunk-groups, maybe like the following:
trunk group CUSTOMER1
description B Channels reserved for Emergency Calls
controller E1 6/0
framing NO-CRC4
pri-group timeslots 1-31 nfas_d primary nfas_int 0 nfas_group 0
trunk-group CUSTOMER1 timeslots 1-2
trunk-group CUSTOMER2 timeslots 20-31
controller E1 6/1
framing NO-CRC4
pri-group timeslots 1-31 nfas_d none nfas_int 1 nfas_group 0
interface Serial6/0
no ip address
interface Serial6/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-ni2c
isdn incoming-voice modem
isdn rlm-group 1
no isdn send-status-enquiry
isdn negotiate-bchan resend-setup
voice-port 6/0:D
dial-peer voice 7099 voip
destination-pattern xxxxx
progress_ind setup enable 3
voice-class codec 1
session target ipv4:xxxxx
dial-peer voice 9999 pots
trunkgroup CUSTOMER1
huntstop
direct-inward-dial
port 6/0:D
Would this work? Do we have to change something in the PGW in order to make this config work? Any help would be very appreciated.
Overall Rating: 4 (1 ratings)
Marwan ALshawi Sat, 10/04/2008 - 00:33
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
CarlosEduardo Fri, 10/17/2008 - 09:44
Thanks marwanshawi.
We configured the solution so a customer would use only two timeslots, and it works ok when there are just two calls, but when the third call tries to connect, it should receive a busy tone or something like that, but that's not happening, instead of that, we get a message like this "the number you dial don't exist, please try again".
Any hint on what's going on? is there something we could do on the AccessServer or the PGW ? Thanks in advance.
