5505 ASA with Base license L2L & easy VPN capacity
Oct 3rd, 2008
  • Gold, 750 points or more
Hi All,
I have couple of ezvpn hardware cleints ( ASA5505) clients connects to VPN3000 at central location.5505 got base license and basic ezvpn configs. Please see below..
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : 10
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs :Disabled
VLAN Trunk Ports : 0
This platform has a Base license.
EZVPN client config:
vpnclient server 7.50.2.17
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup HOME password ***
vpnclient username user1 password ***
vpnclient enable
Now with the above license and running with ezvpn, will the ASAs support L2L tunnel in between 2 client sites, so that the client networks can speak directly..? or is it recomended to go with 'hairpin' vpn.
Thank you
MS
Overall Rating: 4.5 (2 ratings)
Marwan ALshawi Sun, 10/05/2008 - 01:08
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
both works
if u have a static public IP for each ASA and vpn3000 u can do it L2L between all of them
if the bandwdith on the central site enoguh 'hairpin' good choice as well to make each ASA has one L2L tunnel and the vpn3000 will do the 'hairpin'
if u dont have public IPs for the ASAs u may do it like what u have done
if helpful Rate
mvsheik123 Sun, 10/05/2008 - 05:05
Great.Thank you. What if both cliet sites getting DHCP assigned IP from local carrier.. then as you recomended 'hairpin' is the choice..?
Thank you
MS
Marwan ALshawi Sun, 10/05/2008 - 15:25
if both geting IPs from DHCP then no static IP in the case both of ASAs needs to be ezvpn clients to the vpn3000 and after they connect u they can comunicate through 'hairpin'
good luck
if helpful Rate
