How to setup a (2 tier) Client - Server arch.
Oct 3rd, 2008
How can I use two machines to establish a client-server arch.
What are possible scenarios ?
What sw,hw I will require in each scenario ?
Gilles Dufour Mon, 10/06/2008 - 04:46
  • Cisco Employee,
back to basics here.
1 machine is the client and the other one the server.
Basic: the client telnet to the server. You just need a server that allows telnet.
Or slightly more complex, the client open a connection the web server to download a page.
You then need a browser on the client and a web application on the server.
Your question is very generic.
If you are in the learning process, I would suggest to buy a book on tcp/ip and start from there.
Gilles.
