ASA as failover
Oct 4th, 2008
We have a ASA 5505,
Requirement:
We have two broadband with static ip, we want to implement failover mode if one connection goes down second one take the load automatically.We want ipsec tunnel to access remote subnet from local LAN thru internet.
is it possible ?
Overall Rating: 2 (1 ratings)
satish_zanjurne Sat, 10/04/2008 - 11:27
  • Silver, 250 points or more
From the title of your post it looks like it is ASA Failover i.e IF active ASA fails, then standby should take over.
But from the description of the requirement, it looks like it link failover.
So i assume here it is link failover.
I assume you have 2 broadband connections on 2 different routers.
Refer below mentioned link which explains how to run HSRP for IPSec high availability.
HTH...rate if helpful..
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/white_paper_c11_472859.html
