Connect R2821 CCME to CE500 24PC
Oct 4th, 2008
Hi All,
I have a problem about connect using Smartport rule a router 2811 ccme to a catalyst 500-24PC. On router run the VoIP system and I have 2 VLAN one default and one Cisco-Voice, but if I configure on one port for 2821 the "router" rule the voice VLAN cannot to be selected. Which is the correct rule to do communicate correctly some IP phone (rule = IP Phone + desktop) and router con CCME?
Thank you for best support
Best Regards
Tonino
ivillegas Thu, 10/09/2008 - 13:48
The port roles are based on the type of devices to be connected to the switch ports.
IP Phone + Desktop: Apply this role to ports that are connected to IP phones.
A desktop device, such as a PC, can be connected to the IP phone. Both the IP phone and connected PC have access to the network and the Internet through the switch port. This role prioritizes voice traffic over data traffic to ensure clear voice reception on the IP phones.
Refer the URL: Catalyst Express 500 Series Switches Configuration:
http://www.cisco.com/en/US/products/ps6545/products_configuration_example09186a00806da6c9.shtml
