IOS Upgrade 2621Router
Oct 4th, 2008
HI Friends
I tried to upgrade the IOS of my router 2621. The image i istalled is c2600-i-mz.123-21b.bin. It is succefully installed but when i rebooted the Router it is not not detecting the WIC card at W0 and W1 slot. I have WIC1 ADSL card on these slots.
The imgae i was using before was 12.2.15-15T. I am having some problem with the ADSL line, the link was keep on flapping after a cable cut from the Telco. As solution i tried to upgrade the IOS and FW of the device for a try.
Can any one hlp me by suggesting an IOS for the router.
32Mb RAM
16Mb Flash
Attaching the sh ver & Flash
regards
Jacob
Jacob Samuel Sun, 10/05/2008 - 02:03
Thanks Vel, but the 12.2(4)T is seems Deferral Image, it is not available in the cisco site to download. Also my router spec is not meeting the minimum requirement for that, needs 64Mb RAM.
Is there any other image that can support
Thanks for your valuable inputs
Jacob
