VG 202 / 204
Oct 4th, 2008
Hi, can anyone tell me what the new VG 202 or 204 gateways are? they have less ports than a VG-224 and VG-248 ?
rob.huffman Sat, 10/04/2008 - 11:49
Hi Carl,
Yes, these newest Cisco Gateways offer support for 2 or 4 (VG202 and VG204 respectively) FXS Ports.
Cisco VG202 and VG204 Gateway Support in Cisco Unified Communications Manager Administration
The Cisco VG202 and VG204 Analog Voice Gateways augment the Cisco Voice Gateway portfolio along with the Cisco Integrated Series Routers (Cisco 3800,2800,1861 and VG224s). These gateways enable an IP telephony solution to continue using traditional analog devices while taking advantage of the productivity that an IP infrastructure affords.
The Cisco VG202 and VG204 comprise Cisco IOS Software-based 2-port and 4-port gateways for analog phones, fax machines, modems, and speakerphones within an enterprise voice system that is based on Cisco Unified Communications Manager and Cisco Unified Communications Manager Express.
After the Cisco VG202 and VG204 release, you can configure the gateways in Cisco Unified Communications Manager Administration.
Hope this helps!
