no DTMF tones when I dial digits out to PSTN
tbrokaw
no DTMF tones when I dial digits out to PSTN. I get digit tones when dialing IP phone to IP phone though. Just not out to the PSTN. This system is in Switzerland, so Swiss Telecom. dial-peers below. What am I missing?
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
forward-digits all
dial-peer voice 11 voip
incoming called-number .T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1000 pots
description <==10 Digit Local Dialing==>
preference 1
destination-pattern 0[1-9]........
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 1/0/0:15
forward-digits all
dial-peer voice 1001 pots
description <==INT Digit Local Dialing==>
preference 1
destination-pattern 00[2-9]%
direct-inward-dial
port 1/0/0:15
forward-digits all
I can't seem to find what else to add.
gogasca
Level 10
Level 10
could u please check which is your incoming voip-dial-peer when dialing to pstn, per config it may be 11.
In that one add both 245 alphanumeric and h245-signal
CUCM understands incoming h245 alpha and sends h245 signals for dtmf
gogasca
Level 10
Level 10
One of thing, our 7921 wireless phones have no dtmf tone while dialing. Is this a default characteristic?
