dhcp on Vlan
Oct 4th, 2008
I have two Vlan on my network which is deployed on several switches connected in trunk, with addresses 192.168.1.0 ( Vlan default ) and 10.0.0.0 ( Vlan2 of guests in our hotel ).
Each of this Vlan have its DHCP configured on dedicated servers.
Yesterday I have chanced on one port from "switch access vlan 2" to "switch access vlan 1" but the PC connected at this port don't acquire address of 192.168.1.0.
What's can I control ?
What's can be ?
thanks and best regards
Lorenzo
Marwan ALshawi Sun, 10/05/2008 - 00:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
as long as the port is access port
make sure that the following command has entered on the interface level
spanning-tree portfast
also from the switch make sure u have connectivity to the dhcp server
on the dhcp server try to restart dhcp server service
on the client try to disable and enable the network connection if it is windows client from mynetwork places properties disable and enable the connection of ur ethernet
if helpful Rate
