CUCM5 Disaster Recovery System Issue
Oct 5th, 2008
Dear All,
what is the best SFTP server software
that we can use to take a back up for CUCM5 in the Disaster Recovery System page ?
I tried "Core FTP" and "FreeSSHD" ,but i got the same error in CUCM which is "Update failed : Unable to access SFTP server. Please make sure the login credentials and path are correct."
Kindly advice what can i do?
Overall Rating: 5 (1 ratings)
ebreniz Fri, 10/10/2008 - 12:25
  • Silver, 250 points or more
FreeFTPD is the best recommendation on a SFTP server to use to back up CUCM. I have also experienced on similar problems with the FreeFTPd tool as SFTP what you are facing now. The way I have configured it is as follows:-
1. Under SFTP configure the SFTP root directory for example E:
2. Create your user and configure the home directory E:\Backup
3. Under virtual directories create a folder named Backup, set the virtual to Backup and configure the real path to E:\Backup
4. When you configure the DRS network location specify / for the path name.
eemara949 Sat, 10/11/2008 - 22:38
Thanks a lot Mr. Edgar for your help. My problem solved completly.
