10-05-2008 05:20 AM
I have problem with LMS2.5 and restorebackup.pl.
I'm moving CWLMS win2k to CWLMS win2003.
1) perl script:
d:\CSCOpx\bin\perl d:\CSCOpx\bin\restorebackup.pl -d f:\backupCW04v\96 -t f:\temp
2) result perl script:
error in extracing single file
error in executing the tar_command [-1]
restore failed
3) my restorebackup.log file:
--> attachment
Any ideas why the restore failing?
Thanks for any help you can provide.
Ok update patch for LMS2.5 resolved my problem
Solved! Go to Solution.
10-05-2008 08:17 AM
This is a bug. You will need to upgrade to LMS 2.5.1 or higher to fix it. It sounds like you already did that. If you haven't done so, you should also upgrade to LMS 2.6 SP1 as we have stopped producing device updates for LMS 2.5.x.
10-05-2008 08:17 AM
