privilege level
Oct 5th, 2008
Hi all. I would like to know what are the exact differences between the various privilege levels 0-15 in asa5510. Is there a website that explains this? In my asdm, under aaa access, under authorization tab, under advance button, i can see that there is settings define for level 0,1 and 15. Does it mean i have to define on my own for the other privilege levels? Thks in advance.
donnie Mon, 10/06/2008 - 20:18
Hi Thks for the response. Yes this is what i am looking for. However when i type "show running-config privilege level" only level 3 and 5 show some output as shown below.
FW# show running-config privilege level 5
privilege cmd level 5 mode exec command configure
privilege show level 5 mode exec command running-config
privilege show level 5 mode exec command clock
privilege show level 5 mode exec command fragment
privilege show level 5 mode exec command ntp
privilege show level 5 mode configure command clock
privilege show level 5 mode configure command logging
privilege show level 5 mode configure command fragment
privilege show level 5 mode configure command ntp
privilege show level 5 mode configure command privilege
Whereas level 15 shows nothing. My account in asa5510 is using level 15. Why is this so? Pls advise. Thks in advance.
