CME FXO to Centrex long distance code problem
Oct 5th, 2008
I have a UC520/CME connected to a Centrex switch. With the previous PBX and with a but-set if you dial a long distance number, 9-1-234-564-7890, the Centrex swtich sends back a "tone" that indicates the user needs to then enter an access code. User enters the access code and the call is completed.
Problem: With the UC520 connected, the user is not hearing the "tone" and is not able to enter the access code, therefore long distance calls fail.
Any ideas?
Thanks.
Marwan ALshawi Sun, 10/05/2008 - 15:17
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
lets say ur fxo port 0/0/1
u need to have somthing like:
dial-peer voice 9 pots
destination-pattren 91..........
dtmf-relay h245-alphanumeric
port 0/0/1
forward-digits all
or forward-digits [number of digits u wanna send out of ur fxo]
good luck
if helpful Rate
m-ketchum Mon, 10/06/2008 - 07:39
The dial-peers were matching as the calls would get the PBX, but just wouldn't complete a long distance call due to no access.
Strangely enough the problem seems to have resolved itself.
Thanks for the reply.
