Changing SNMP
johnlloyd_13
Level 9
Level 9
all,
we have set ro snmp community strings on our network devices and it was added to our nms. if we changed our ro snmp strings on the devices, will it stop sending traps to our nms and do we have to re-learn the device again?
smalkeric
Level 6
Level 6
You may try using “snmp-server host” command. snmp-server host command specifies the recipient of all SNMP notifications and is used to configure the SNMP agent to send either traps or informs to multiple hosts. It is possible to use multiple instances of this command to specify more than one notification recipient.
Refer the below URL:
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf014.html#wp1056809
smalkeric
Level 6
Level 6
