ACE 4710 SAML Tokens
Oct 5th, 2008
I am using an ACE 4710 and am converting incoming WSS username tokens to SAML Tokens - authenicating against Tivoli directory.
The receiving web service is attempting to validate the SAML token but fails on digest verification. i.e. calculates the digest value over the SAML token and compares to the digest in the Xml Signature block.
Is anybody else using SAML tokens?
Has anyone else seen a similar problem?
vmoopeung Fri, 10/10/2008 - 12:02
By adding SAML assertions to outgoing requests, the ACE XML Gateway can act as an asserting party for systems that rely on SAML credentials. The SAML assertions generated by the ACE XML Gateway can be in the form of a SAML 1.0, SAML 1.1, or SAML 2.0 credential.
The following url may help you;
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_xml_gateway/v52/user/guide/axg_ug_backendauth.html#wp1049962
