silnce when press *
Oct 6th, 2008
We have unity 5.x networked and using cross server login. Generally all works fine but just now and then when users dial in via pstn and press * key they get silence - they generally disconnect and try again and it works fine.Anyone seen this?...cheers, Jaginder
Overall Rating: 2 (1 ratings)
askq2forum Tue, 10/07/2008 - 13:09
Stephanie,
its a single gateway and the issue is intermittent - so I think if the gateway config was wrong then it would never work. Thanks for your reply,Best wishes...J
Chad Stachowicz Tue, 10/07/2008 - 18:33
  • Silver, 250 points or more
What protocol from the gateway to the CCM?
Chad
askq2forum Wed, 10/08/2008 - 05:11
Chad,
QSIG E1 from Realitis to IOS gateway then H323 to CUCM
