VPN terminated on Loopback IP
Oct 6th, 2008
Hi all,
I'm willing to configure a VPN client on my 2691 router [run IOS ver. 12.4(15)T7]. the network setup is quite simple, as following
ADSL router --> VPN router
I've configured a loopback 0 to terminate the VPN sessions but to no avail, for curiosity reason I've tried to terminate the VPN on the Fa0/0 and amazingly working fine.
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration address-pool local dynpool
crypto isakmp client configuration group hasan-gr
key hasan-key
dns 10.0.0.2
wins 10.0.0.2
pool dynpool
crypto ipsec transform-set transform-1 esp-3des esp-sha-hmac
crypto dynamic-map dynmap 1
set transform-set transform-1
reverse-route
crypto map dynmap isakmp authorization list hasan-gr
crypto map dynmap client configuration address respond
crypto map dynmap 1 ipsec-isakmp dynamic dynmap
interface Loopback0
ip nat inside
ip virtual-reassembly
crypto map dynmap
interface FastEthernet0/0
ip address 10.0.0.60 255.255.255.0
ip nat outside
speed 100
full-duplex
ip nat source static 192.168.1.1 10.0.0.131
ip local pool dynpool 192.168.74.200 192.168.74.220
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.0.2
any helpful comments will be higly appreciated..
Overall Rating: 3 (1 ratings)
cisco24x7 Mon, 10/06/2008 - 05:48
  • Silver, 250 points or more
Your loopback 0 needs to be visible for this
to work.
Richard Burts Mon, 10/06/2008 - 07:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
For the VPN tunnel to work when terminated on the loopback it would also be necessary to configure the crypto map local-address command. By default the crypto will use the address of the outbound interface. So when terminating the VPN on the physical interface local-address is not needed. To use the loopback you need the configuration command to change the address used from the physical outbound interface to the loopback.
Rick
