High CPU use in 3550
Oct 6th, 2008
Hi All,
I'm facing the following problem and before I contact Cisco TAC, I want to drop a line here.
I've got a C3550-IPBASE-M running IOS Version 12.2(25)SEE2. It's got two L3 VLAN interfaces. All Interfaces are placed in on. I've got one static route and 1 ACL's with 5 rule.
Basically, the setup is a border router connected to our internetlink. Traffic is about 40Mbps sustained, 100Mbps peak.
I've got a second 3750 connected to the same ISP. It's doing the same. Both 3750 use HSRP for redundancy.
Now, CPU usage shoots up to 90-99%.
I'm not using IPv6
No Logging is enabled
No individual process is using more than 1% of processor.
I am using the no ip access list command. But CPU usage is same.
System mtu is 1500
No IPSEC/GRE tunnel interface.
Using ip cef.
Anyone please help about that matter.
RicheeJJJ_2 Mon, 10/06/2008 - 04:40
do show proc cpu sorted
This will tell you which process are using the most memory starting with the highest first. Post which process is using up all this cpu and we can help you more.
RicheeJJJ_2 Mon, 10/06/2008 - 06:55
Do this:
sh proc cpu | exclude 0.00%__0.00%__0.00%
Use a calculator, add them all up, and see if it's 99%. If it's not 99% then yes it's a TAC case. Because your cisco router can't do basic math and who knows what else it isn't doing right.
shahjahansiraj Mon, 10/06/2008 - 07:23
VOIP(config)#do sh process cpu | exclude 0.00
CPU utilization for five seconds: 95%/94%; one minute: 96%; five minutes: 96%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
29 126056688 201933850 624 0.47% 0.75% 0.92% 0 Vegas LED Proces
37 289839368 26181425 11070 0.47% 0.47% 0.49% 0 Vegas Statistics
38 13868684 118710584 116 0.15% 0.08% 0.09% 0 HMATM Learn proc
genusys(config)#
nate-miller Wed, 10/08/2008 - 06:04
  • Bronze, 100 points or more
the 95%/94% indicates that 95% of your processor is being used, and 94% of it is interrupt driven, rather than process driven. You won't see these interrupts in the process list.
If you've got it hooked up to an ISP, how many routes are you getting on it?
Look at the command "sh sdm prefer"
This shows how the TCAM on a 3750 has been allocated. By default, a 3750 can only store 2000 IPV4 routes. It uses enough TCAM to store 6000 MAC addresses.
By using the config command "sdm prefer routing", you can juggle the TCAM around so it can handle more routes.
sh ip route summary
This will tell you how many subnets you're actually learning. If these numbers don't match up with the SDM numbers, I would apply the new SDM profile and reboot- and see what happens.
If this isnt' the case, there's more you can look at- but this is what caused my network to choke the first time I saw this.
shahjahansiraj Wed, 10/08/2008 - 07:49
This is the result of sh ip route summary command
VOIP#sh ip route summary
IP routing table name is Default-IP-Routing-Table(0)
IP routing table maximum-paths is 32
Route Source Networks Subnets Overhead Memory (bytes)
connected 0 4 256 608
static 1 0 64 152
internal 3 3516
Total 4 4 320 4276
genusys#
netwalkr1 Wed, 10/08/2008 - 06:27
I saw a similar scenario once before. The customer had a Metro Ethernet connection from the SP. The default route next hop was set the the FE interface, not the next hop address. The ARP table would populate with all the destinations being on the Internet and destroy the router (1721). This *may* be due to proxy-arp being enabled by default on the older code running on the platform. I changed the default to the next hop IP and it resolved the problem.
