Cisco Security Manager Perfomance Monitor 3.2.1 generate strange message
Oct 6th, 2008
This message generate periodicly:
____________________
FaultId: 27
DeviceId: 450
DeviceIP: 172.23.29.5
DeviceName: 172.23.29.5
MO: Device
Change: Device is not accessible via HTTPS - Either the credentials are incorrect or Https may not be enabled on the device
ChangeSeverity: P1
StateChange: Device Accessible via Https is Down
AlarmState: Active
OverallSeverity: P1
DeviceType: Firewall
____________________________
But device still accessebel by HTTPS. I see there are no timeout configure by HTTP access (only SNMP timeout).
PS. Device successuful import to PM. And I recive a messages from this device.
bwilmoth Fri, 10/10/2008 - 12:24
  • Silver, 250 points or more
MCP uses HTTPS for periodic polling to Firewall, the interval may vary
depends on the default polling interval ( default 5min ) and the size of the network.If you think this unreachable event is due to netowork cogestion or intermittent problems.
Then you can use the following steps:
1. Admin->Events->Firewall
2. Select "Device Accessible" , click 'Thresholds'.
