vpn client through firewall issue
Oct 6th, 2008
Dear all
i have an ASA 5520 in my company and it is working fine , all the users can access internet through it . i faced a problem that when trying to use the vpn client S/W which installed on my pc to connect to remote networks from my company , i found that the vpn tunnel is established successfully and in the system tray i noted that the vpn client is connected .
But when trying to access any device in the remote networks , i failed. I tried to ping any device or server but it failed . Also i tried to connect to any server using remote desktop , but it failed.
From my home i can access these remote networks properly without any problems through my ADSL line .
i cannot detrmine where the problem is .
please i need your advice.
please find the attached file for ASA config.
regards
Mohamed
cisco24x7 Mon, 10/06/2008 - 04:21
  • Silver, 250 points or more
"isakmp nat-traversal 10" needs to be enable
on the remote VPN device. That way, it can
detect if your system is behind a NAT device.
mohamed_makled Mon, 10/06/2008 - 05:27
Thanks dear for your reply.
i need to know that it is necessary to add this command in my ASA also or just the remote vpn device ??
regards
cisco24x7 Mon, 10/06/2008 - 05:45
just the remote VPN device. You do NOT have to
do anything on your ASA.
