Migration CSA agents 4.5 to 6.0
Oct 6th, 2008
Hi all,
I'm planning to migrate a CSAMC from 4.5 to 6.0 on the same machine. I understand that I need to upgrade firs to 5.0, than back-up the config, database etc and reinstall the whole system for 6.0. I'm not sure if I need to migrate my agents first into 5.0 then into 6.0, or I can migrate clients from 4.5 immediatelly into 6.0.
Many thanks!
Tamas
Overall Rating: 5 (1 ratings)
tsteger1 Tue, 10/07/2008 - 21:24
I believe the migration can be from 4.5 to 6.0 though I haven't performed this.
They will still have the 4.5 agent and report to the 6.0 MC and the 6.0 agent kit should be an available update.
Tom
teperjesi Tue, 10/07/2008 - 22:09
Unfortunately the answer is no. I need to pool every agents into every new versions.:(
tsteger1 Thu, 10/09/2008 - 13:37
Bummer. The documentation wasn't terribly clear on the sequence.
Tom
