Static IP access from Inside
Oct 6th, 2008
I have configured ASA with three interface
Inside - 192.x.x.x
Outside - 203.x.x.x
DMZ - 172.x.x.x
one of the DMZ ip is static nated to Public IP
i.e static (dmz,outside) 203.x.x.5 172.x.x.2 netmask 255.255.255.255
My requirement is i shoud be able to ping/access Natted public IP 203.x.x.5 from inside instead of private IP 172.x.x.2
Can any one suggest solution for this.
Sri
acomiskey Mon, 10/06/2008 - 04:53
  • Green, 3000 points or more
static (dmz,inside) 203.x.x.5 172.x.x.2 netmask 255.255.255.255
That's all you need.
srikanth-m Mon, 10/06/2008 - 23:31
This worked out, thanks but now I am not able to access the server using praivate IP i.e. 172.x.x.2 from inside (from192.x.x.x)
my requirement is to access server in both ways, as some of the users require to access by public IP and remaining all users will access server using praivate IP
