how to re-authenticate / re-authorization "configure terminal" command ?
Oct 6th, 2008
To aviod our network engineers enter router config mode by accident, we are looking for a way to let ACS server re-authenticate (popup a username & password prompt)users when they enter "configure terminal" command...
Can you guys help me out ?
Jerry
jerrytozhang Mon, 10/06/2008 - 07:56
Hi,Jgambhir:
Thanks for your notes.
But my point is that our engineers need full privileges including "config t" on routers to do some modification tasks during a maintenance window.
What I want to do is that when they enter "config t", is there any way on ACS to let routers prompt a username & password to let our engineers re-input their credential before entering router config mode ?
Jerry
Jagdeep Gambhir Mon, 10/06/2008 - 10:41
Jerry,
I don't think there is any way to achieve that.
Any specific reason why you what that way ?
~JG
Do rate helpful posts
