SDM in 2800 router
Oct 6th, 2008
I have a really simple (hopefully) question. I run several IPS in IOS SDM for my customer and they are looking for a list of signatures that we have applied. I have several hundred applied obviously and I can't find a good place to get a list. No where in the zip file nor can I export the list from the GUI. I have also searched Cisco and maybe I am just overlooking. Even if I can get a generic list that I can narrow down, that would be fine. I just need the list without having to hand type all 500 signatures into a spreadsheet.
dazza_johnson Mon, 10/06/2008 - 07:35
Hi there. Do you have CLI access to these routers? If so, try 'show ip ips signatures' this should tell you all the information you need (add 'detail' to the end to get additional signature info!).
