Router Shopping
Oct 6th, 2008
Hi. I am looking for an advanced router that can perform:
1. Load balancing of 2 high speed internet connections (fast ethernet ports).
2. Bandwidth management per LAN port or IP address (minimum of 4 LAN fast ethernet ports).
3. Report on bandwidth usage per ip address or LAN port.
4. Report on ISP down time.
satish_zanjurne Mon, 10/06/2008 - 10:50
  • Silver, 250 points or more
For your requirement L3 switch would be good.
For that matter Catalyst 3750 is best.
WS-C3750G-24TS-E
24 Gigabit Ports , Fiber Uplinks, Enhanced Mulitlayer Image allows OSPF,BGP
Refer below mentioned Data Sheet link
http://cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
HTH...rate if helpful...
