Headset with softphone and wirless network connection
Answered Question
Oct 6th, 2008
I am unable to get 2 way audio when I use headset on wireless connection? I can hear the caller but they can not hear me. Can anyway make suggustion on this. Plantronics audio 625 USB
Correct Answer by testeven about 8 years 5 months ago
Hi!
First of all please check that you are using a supported wireless headset from the link below:
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K11914409
Tere.
Overall Rating: 3 (1 ratings)
drubery Mon, 10/27/2008 - 10:27
Have you walked through the Audio Tuning Wizard with the headset connected. You may have also have to access the advanced audio features of your PC and disable the built in microphone.
patty_spieker Mon, 10/27/2008 - 10:59
This does not work either. The headset is not compatiable with phones.
