10-06-2008 08:59 AM - edited 03-15-2019 01:45 PM
I am not able to use(its not workig) Illuminated Buttons services in 7914 expansion module.So pls help me out to config/enable this service in CCM 4.1...thanks in advance.
ok let me tell u what the setup is i have 7961G phone use for reception and expansion module 7914 is attached to it and i am using CCM 4.1(3)SR2.
Solved! Go to Solution.
10-06-2008 12:33 PM
Hello Shamkumar,
you need to upgrade the CCM to later version
Busy LAmp field are part of Cisco Presence
Cisco Unified Presence encompasses the following components, illustrated in Figure 23-1: â¢Cisco Unified Presence server â¢Cisco Unified Communications Manager (Unified CM) Release 5.0(4) or higher
from SRND for CUCM 6.0.x
Hope to help
Giuseppe
10-06-2008 10:07 AM
4.1(3) did not support BLF buttons, therefore you will not be able to use this feature until you upgrade to a version that added the BLF button functionality.
HTH,
Steve
10-06-2008 10:56 AM
thanks for ur quick response..would u explain me what i need to upgrade,is that firmware or ccm version.coz i upgraded firmware of phone 7961 and 7914 very recently.it will be very helpful to me if u explain me in detail...
thanking you
shamkumar.m
10-06-2008 12:33 PM
Hello Shamkumar,
Hope to help
Giuseppe
10-06-2008 02:06 PM
Thanks a lot friends...it helped me a lot...ones again thanks..
