What is process name "68 Dispacth Unit" on 515e 7.22?
Oct 6th, 2008
One of my firewalls 515e on 7.22 has a very busy process named "68 Dispacth Unit"
Does anyone recognize this process name? I can't tell what it is and why it has so much more CPU time than other legitimate processes.
Thanks in advance for your thoughts.
ajagadee Mon, 10/06/2008 - 17:12
I am not sure what "Dispatch Unit" but when I see a bunch of Bug IDs in the release notes for a various versions of the ASA.
Below is the URL for release notes, just look for "Dispatch Unit" and you should see some bugs listed there. Take a look at it and see if you are running into any of the bugs listed in the release notes.
** Please rate all helpful posts **
emaestas Tue, 10/07/2008 - 08:22
I can't tell for sure. The Pix is not encountering any traceback because of this. It seems to be a utilization issue right now. Does this entry reveal anything more?
The actual process entry is:
Mrd 00218f77 01ac46c4 013a9470 824168456 01abc740 26904/32768 Dispatch Unit
