singhsaju Mon, 10/06/2008 - 11:01
Resolved.I was plugged in to Aux port! changed it to console , now everything is ok.
satish_zanjurne Mon, 10/06/2008 - 11:06
Following steps should work
1.Press the Break key during the first 60 seconds while the system is starting up
2.Use confreg 0x2142
3.reset
4.It will boot without the startup config
5.enable
6.copy start run
7.config t
8.enable secret
9.config-register 0x2102
10.write mem
HTH...rate if helpful..
