Routing traffic on the same subnet
Oct 6th, 2008
Can you route traffic from one router to another on the same network? I am trying to route traffic coming over a private T1 out to a Linux router that sends traffic to a load balancer. I have two 1841s handling the T1 which I need to pass the traffic to the Linux router. The 1841 in the main office has a Fastethernet interface assigned to a address and the Linux router is on the same network. What are my options to get this 1841 to pass traffic to the Linux router?
Jon Marshall Mon, 10/06/2008 - 17:55
If i understand you correctly then yes you can do this, in fact this is what routers do all the time. You just need to add a static route to your 1841 or run a routing protocol between your 1841 and the Linux box which would very probably have to be RIP so a static is probably the best solution.
So if you wanted all traffic destined foer to go to the linux box then on the 1841
ip route
If however your 1841 had an interface in the 192.168.5.x network then no you couldn't route via the linux box.
jstewart33 Tue, 10/07/2008 - 05:40
Thanks Jon for your reply. I do indeed have an interface on the 1841 that is on the same network as the linux box. So what are my options? Can I just change the IP on the 1841 to a different network and then route traffic to the linux box on the Right now the 1841 FastEthernet interface and the linux box interface all reside on the same switch. Is this the correct way to cable them?
