T1 Controller Down
Oct 6th, 2008
Good evening everyone. Hope someone can help me figure this one out. This past weekend I converted a client from a Nortel Option 81 to a Cisco system running 6.1(2). The local PRI's came up just fine but the long disatance T1 never came up. I get "Carrier Detect" but I'm seeing a lot of "Line Code Violations". Their DMARC and SmartJack is just out side their suite and extended into their suite via Cat5 and terminated on a patch panel. I can place a loopback plug in the port on the patch panel where the T1 is patched and my controller comes up. When I place the circuit inline, I get the errors and the controller goes down. The weird thing is I can plug the T1 back into the CSU/DSU that goes to the Nortel system and it will come up and I can make long distance calls. Any help is greately appreciated.
T1 0/0/1 is down.
Applique type is Channelized T1
Cablelength is short 133
Transmitter is sending remote alarm.
Receiver has loss of frame.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20040802, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (890 seconds elapsed):
7289990 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 890 Unavail Secs
Total Data (last 23 15 minute intervals):
163647851 Line Code Violations, 69747 Path Code Violations,
102 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
6 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 20551 Unavail Secs
Chad Stachowicz Mon, 10/06/2008 - 17:59
  • Silver, 250 points or more
would you mind pasting the full config of the router 'sh run' and a 'sh isdn status'.... lastly are u using the original cable from the old T1 to the nortel or a new cable?
Chad
keith-williams Mon, 10/06/2008 - 18:23
Hey Chad thanks for the quick reply. Below is a sh run command. I did not do a sh isdn status because this is a T1 so there isn't an ISDN status. I am using the original cabling that extends into the suite but I have a T1 Crossover cable running from the patch panel to the T1 card. I took out the crypto to save space.
Godwin_Dallas_3825#sh run
Building configuration...
Current configuration : 9885 bytes
! Last configuration change at 20:42:04 DST Mon Oct 6 2008 by admin
! NVRAM config last updated at 14:06:23 DST Mon Oct 6 2008 by admin
version 12.4
service password-encryption
hostname Godwin_Dallas_3825
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 2
card type t1 0 3
logging buffered 4096 informational
enable secret 5 $1$rzPS$DTmPZGi/ry6fZZB1uDvYm/
no aaa new-model
resource policy
clock summer-time DST recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
network-clock-participate wic 0
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 T1 0/0/1
ip subnet-zero
ip cef
ip domain name legaleagles.law
ip name-server 10.10.10.55
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
supplementary-service h450.12
h323
voice translation-rule 1
rule 1 /5\(.........011\)/ //
voice translation-profile InternationalCall
translate called 1
controller T1 0/0/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start
controller T1 0/0/1
framing esf
linecode b8zs
cablelength short 133
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24
controller T1 0/2/1
framing esf
linecode b8zs
controller T1 0/3/0
framing esf
linecode b8zs
class-map match-any VOIP
match ip dscp ef
match ip dscp cs5
class-map match-all ALLOTHER
match input-interface GigabitEthernet0/1
class-map match-all VIDEOOUT
match ip dscp af41
class-map match-all VIDEOCONFERENCING
match source-address mac 0050.6001.A98A
class-map match-all other
class-map match-any VOIP-SIGNALING
match ip dscp af31
match ip dscp cs3
policy-map VOICEPOLICYOUT
class VOIP
priority percent 30
class VIDEOOUT
bandwidth percent 10
class VOIP-SIGNALING
bandwidth percent 5
class class-default
fair-queue
policy-map UNTRUSTED
class ALLOTHER
set ip dscp default
policy-map VIDEOIN
class VIDEOCONFERENCING
set ip dscp af41
interface Loopback64
ip address 10.254.228.254 255.255.255.255
interface GigabitEthernet0/0
description Dallas connection to Cogent to Houston
ip address 10.133.13.21 255.255.255.0
shutdown
duplex full
speed 100
media-type rj45
no negotiation auto
service-policy output VOICEPOLICYOUT
description 3825_to_Core
ip address 10.10.77.4 255.255.255.0
duplex full
speed 100
media-type rj45
negotiation auto
interface FastEthernet0/1/0
description Gateway for Videoconferencing in Dallas
switchport access vlan 100
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
keith-williams Mon, 10/06/2008 - 18:24
interface Serial0/2/0:23
no ip address
isdn incoming-voice voice
no cdp enable
interface Serial0/2/1:23
no ip address
no cdp enable
interface Serial0/3/0:23
no ip address
no cdp enable
interface Vlan1
no ip address
interface Vlan100
ip address 10.10.30.2 255.255.255.0
service-policy input VIDEOIN
router rip
version 2
network 10.0.0.0
network 198.168.1.0
network 198.168.10.0
network 198.168.17.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.77.2
ip route 10.11.25.0 255.255.255.0 10.133.13.6
ip route 10.11.27.0 255.255.255.0 10.133.13.6
ip route 10.11.29.0 255.255.255.0 10.133.13.6
ip route 10.11.30.0 255.255.255.0 10.133.13.6
ip route 172.31.240.0 255.255.255.0 10.10.26.254
ip http server
no ip http secure-server
control-plane
voice-port 0/2/0:23
input gain 3
output attenuation -3
echo-cancel coverage 24
voice-port 0/3/0:23
input gain 3
voice-port 0/0/0:0
voice-port 0/0/1:0
voice-port 0/2/1:23
input gain 3
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/2/0:23
dial-peer voice 2 pots
direct-inward-dial
port 0/2/1:23
dial-peer voice 3 pots
direct-inward-dial
port 0/3/0:23
dial-peer voice 4 pots
destination-pattern 9[2-9].........
progress_ind setup enable 3
progress_ind progress enable 8
port 0/2/0:23
forward-digits 10
dial-peer voice 5 pots
port 0/2/1:23
forward-digits 10
dial-peer voice 6 pots
port 0/3/0:23
forward-digits 10
dial-peer voice 7 pots
destination-pattern 5.........1[2-9].........
port 0/2/0:23
forward-digits 11
dial-peer voice 9 pots
destination-pattern 911
port 0/2/0:23
forward-digits all
dial-peer voice 10 pots
port 0/2/1:23
forward-digits all
dial-peer voice 11 pots
port 0/3/0:23
forward-digits all
dial-peer voice 1000 voip
preference 1
destination-pattern 939[48]...
session target ipv4:10.10.9.11
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2000 voip
session target ipv4:10.10.9.10
codec g711ulaw
no vad
dial-peer voice 2010 voip
preference 1
destination-pattern 7433...
codec g711ulaw
no vad
dial-peer voice 2020 voip
destination-pattern 74335...
codec g711ulaw
no vad
dial-peer voice 13 pots
preference 1
destination-pattern 91[2-9].........
port 0/3/0:23
forward-digits 11
dial-peer voice 12 pots
preference 2
port 0/0/1:0
forward-digits 11
dial-peer voice 8 pots
translation-profile outgoing InternationalCall
destination-pattern 5.........011T
port 0/2/0:23
forward-digits all
Md. Mijanur Rahman Mon, 10/06/2008 - 21:38
Are you sure about the linecode (b8zs) is same as the line? You can check it at Nortel switch config or with the provider. This issue is common where linecode doesn't match.
keith-williams Tue, 10/07/2008 - 10:46
I just talked to the carrier and they confirmed linecode b8zs is what they have configured for this line.
tpolimine Tue, 10/07/2008 - 17:22
i had a similar issue, carrier told me they wer wink start, but had to set my H323 gateway to these settings to work
controller T1 0/3/1
framing esf
linecode b8zs
ds0-group 1 timeslots 1-24 type fxo-loop-start
Md. Mijanur Rahman Tue, 10/07/2008 - 21:00
What the status of layer 1 you see with the command 'sh isdn status'? 'Deactivated' or 'Activating'? Try to collect the same after applying shut/no shut on the controller. If layer 1 stays 'Deactivated', conclusion should be problem at controller card. If the status is 'Activating' then the problem is your connectivity, look for layer 2 status. 'MULTIPLE_FRAME_ESTABLISHED' or 'TEI_ASSIGNED'? Issue the command 'sh int S0/2/0:23', do you see 'Serial0/2/0:23 is reset'?
Also try to reload the router after a 'copy run start', sometimes it brings up layer 2.
keith-williams Thu, 10/09/2008 - 07:38
Hello everyone. Wanted to thank all that replied and let everyone know that the problem has been resolved. Turned out to be an infrastructure problem (bad cable) in the DMARC extention. UGH!!!
Thanks again NetPro's!!
