basic pptp 501 6.3
Answered Question
Oct 6th, 2008
I am attempting to permit a "inside" user who is assigned IP 10.0.0.5 to PPTP to an outside vendor's web server.
can I use "sysopt connection permit-pptp" by itself, or can I use "fixup on port 1723"?
thank you,
wr t
Building configuration...
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password encrypted
passwd encrypted
hostname MJSFW
domain-name macejacobs.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside_access_in permit tcp any any eq 3389
pager lines 24
icmp deny any outside
mtu outside 1500
mtu inside 1500
ip address outside "outside ip" 255.255.255.252
ip address inside 10.0.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 10 10.0.0.0 255.255.255.0 0 0
static (inside,outside) tcp "outside ip" 3389 10.0.0.3 3389 netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 "outside gateway" 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server community warn1ng
no snmp-server enable traps
floodguard enable
sysopt noproxyarp inside
telnet 10.0.0.3 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:
: end
[OK]
MJSFW(config)#
Correct Answer by abinjola about 8 years 6 months ago
fixup protocol pptp 1723
Overall Rating: 5 (1 ratings)
Correct Answer
abinjola Mon, 10/06/2008 - 18:40
  • Cisco Employee,
