documentation on Software upgrade process for NME WAE
Oct 6th, 2008
I have been trying to find documentation on how to upgrade a NME WAE I am setting up a new environment and have the Central manager and Core WAE upgraded to 4.1 by using the recovery disk. the network modules I have are currently running 4.0. I would like to upgrade them using the software recovery process, but I cannot find this process for the WAE
dstolt Tue, 10/07/2008 - 04:48
You cannot use a recovery CD on the NME. You can either upgrade the NME from the CLI using the "copy ftp install" command with the .bin file or you can use a 4.0 CM GUI to upgrade the device.
I would recommend you use "copy ftp install" that is documented here...
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v411/command/reference/execmds.html#wp1043584
Let me know if that helps you out.
Dan
relsethagen Tue, 10/07/2008 - 10:02
If I use the ftp install command to install the bin file do I have to wory about the sysimage file?
