Collin Clark Tue, 10/07/2008 - 11:38
  • Purple, 4500 points or more
How about an ACL? Let's assume vlan 2 is 192.168.2.0 /24 and vlan 3 is 192.168.3.0 /24.
ip access-list extended BLOCK-V2-V3
permit ip any any established
deny ip 192.168.2.0 0.0.0.255 192.168.3.0 0.0.0.255
permit ip any any
Then apply it to the VLAN interface-
ip access-group BLOCK-V2-V3 out
Certainly double check my work before implementing.
Hope that helps.
acomiskey Tue, 10/07/2008 - 11:54
  • Green, 3000 points or more
One small correction. You can only use "tcp" with established keyword.
permit tcp any any established
You can then apply either way you like.
int vlan 2
access-group BLOCK-V2-V3 in
or
int vlan 3
mahendran.a Wed, 10/08/2008 - 21:36
Hey Collin
Thank u for your reply. I tried to configure this command ,but in the permit ip any any established command,the esablished is not working.Could u suggest me wat is the issue
My current version
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA6, RELEASE
SOFTWARE (fc1)
acomiskey Thu, 10/09/2008 - 09:23
See my previous post. You cannot use "ip" with the established command just as you cannot use it for "udp". It must be "tcp".
