CBWFQ - query
pokwan
Can someone advice if the following will work?
access-list 101 permit tcp 100.100.100.2 255.255.255.254 200.200.200.2 255.255.255.254 eq 888
class-map match-all test
match access-group 101
class-map match-any voice-test
match ip dscp ef
policy-map test-policy
class voice-test
priority
class test
bandwidth 3750000
queue-limit 64
class class-default
bandwidth 3750000
queue-limit 64
int te1/1
service-policy output test-policy
With CBWFQ, do you still have to configure the weights, threshold for all queues for the interface?
For example
int te1/1
wrr-queue queue-bandwidth 10 20 10 10 10 20 20
wrr-queue random-detect 1
etc?
TIA
PF
satish_zanjurne
Level 4
Level 4
1.The above policy-map should be good for routers
2.Policy map does not give option of priority instead policy map actions on Catalyst 3550 can include trusting the CoS, DSCP, or IP precedence values in the traffic class; setting a specific CoS, DSCP, or IP precedence value in the traffic class; and specifying the traffic bandwidth limitations for each matched traffic class (policer) and the action to take (marking) when the traffic is out of profile.
3.WRR is a mechanism that is used in output scheduling on the 3550. WRR works between three or four queues (if there is no strict priority queue). The queues that are used in the WRR are emptied in a round-robin fashion, and you can configure the weight for each queue.
4.Gigabit capable ports has egress expedite queue facility using "priority-queue out" command instead of "priority"
So on typical router WRR or SRR is not available
Catalyst 3550 supports WRR
Catalyst 3760 supports SRR
Catalyst 3750 supports SRR
Catalyst 6500 supprts WRR & SRR
For more information WRR on Catalyst 3550 refer below link
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_12c_ea1/configuration/guide/swqos.html#wp1127487
HTH..rate if helpful..
Satish,
Thanks for the reply. We have Cat 6500 switches. We have a tengigabit link joining two locations. The port is capable of 1p7q8t. In our review, we were adviced to use CBWFQ for QoS. The document on CISCO website on CBWFQ did not have the 6500 in the supported platform.
Are you saying that CBWFQ is for routers and not switches? For the 6500, what would you recommend and do you have any examples?
TIA.
PF
