Aironet 1252 Power Inline Cat3560e
Oct 6th, 2008
6 units of Aironet 1252g
1 unit of Catalyst 3560e
Straight out of the box, 5units of my Aironet 1252 are able to power right on when plugged into the Cat3560e, with the "power inline static" command on interface ports.
However 1 unit of it, does not power up. On the switch it indicates power granted. But there is no LED activity at all.
I would like to confirm if this particular 1 AP is faulty? Or is there a special command for it to power on?
jeff.kish Tue, 10/07/2008 - 04:45
It shouldn't require a special command to turn on. Did you try plugging it into the wall? Did you try unplugging the other 5 and plugging this one into one of their switchports?
Maybe plug a console cable in and see if you get anything, just in case the LEDs are bad.
Either way, it sounds like something's wrong with it. That's my evaluation :D
