Agent ACD state log
Oct 6th, 2008
Hy all
i have a Unified CCX Enhanced CRS 5.0.2
My problem is that the Agent ACD state log report indicates that the start time is 1 h ahead of the local time
- the CRS clock is ok
- the O.S of the agent is ok
this problem is only for 1 CSQ
the rest of CSQ are k
tx for answers
mikram Tue, 10/07/2008 - 02:26
What happens when you run supervisor desktop and the agent report indicates the correct time or 1 hour ahead as you mentioned. Please do check both.
cheers
Ikram
Kenneth Mohammed Fri, 10/17/2008 - 08:39
I had this same issue, and I had to install the latest JRE tzupdater patch, make sure the "adjust automatically for DST" box is checked in windows time and restart the box, this rememdied the issue.
