Pls help
Oct 6th, 2008
I m having internet router 2600 series..
Which has 2 mbps leased line circuit.. Recently we have upgraded 2 mpbs to 4mbps.. Now traffic is flowing through both interfaces int s0/0 and s0/1..
which is having static route
ip route 0.0.0.0 0.0.0.0 s0/0
ip route 0.0.0.0 0.0.0.0 s0/1
How traffic is flowing through both interfaces .. Both having static route and administrative distance also same.. when the packet reaches router,how packets forwarded to the interfaces..
satish_zanjurne Tue, 10/07/2008 - 00:17
  • Silver, 250 points or more
1.In show interface are you seeing input/output count increasing for both interfaces ?
2.You can usually use the show ip route command to find equal cost routes , as added by you as static default routes.
3.There is an asterisk (*) next to one of the route block entries . This corresponds
to the active route that is used for new traffic by the router.
4.The term 'new traffic' corresponds to a single packet or an entire
flow to a destination, depending on the type of switching configured.
5.For process-switchingload balancing is on a per-packet basis and the asterisk (*) points to the
interface over which the next packet is sent.
6.For fast-switchingload balancing is on a per-destination basis and the asterisk (*) points to the
interface over which the next destination-based flow is sent.
7.Based on routing table lookup for process switching packet will be sent to appropriate interface
HTH...rate if helpful..
vinothlb1 Tue, 10/07/2008 - 00:46
input /output count is increasing on both interfaces..
As per your suggestion only one static route at a time will it work???
How the traffic count increasing on both interfaces..?
