can't see 7962 on the device list
Answered Question
Oct 7th, 2008
Hi guys,
i have call manager 4.2(3) sr2b.
I run cmterm-7942_7962-sccp.8-4-1SR1.exe on publishwr but a cant add a 7962 new phone because a i don't see it under device list.
Do i miss something?
thx...
Ale
Correct Answer by Rob Huffman about 8 years 6 months ago
Hi Ale,
You would need at least Device Pack 4.1.65 which is compatible with CCM 4.2(3)SR2B
Cisco Unified CallManager Device Package 4.1(65.0) Release Notes
http://download-sj.cisco.com/cisco/crypto/3DES/voice/callmgr/4.1/ciscocm.4-1-DevPack-65.readme.htm
Use these release notes with a Cisco Unified IP Phone 7975G, 7965G, 7945G, 7962G or 7942G running SCCP or SIP firmware release 8.3(5).
The SCCP version of firmware release 8.3(5) is compatible with Cisco Unified Communications Manager releases 6.1 and 6.0, Cisco Unified CallManager releases 5.1, 4.3, 4.2, and 4.1.
Call Control compatibility
Supported in Cisco Unified Communications Manager Versions 4.1(3)sr5b, 4.2(3)sr2b, 4.3(1), 5.1.1(b), 5.1(2), 6.0(1) and greater
Supported in Cisco Unified Communications Express and SRST Version 4.1
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8536/product_data_sheet0900aecd8069bd41.html
Hope this helps!
Rob
Correct Answer by iptuser55 about 8 years 6 months ago
You will need to download the dev pack to have CCM to recongise it as a type of handset- update the device defaults pages- need to check whether 4.2 supports it as well
Overall Rating: 5 (2 ratings)
Correct Answer
iptuser55 Tue, 10/07/2008 - 01:45
  • Silver, 250 points or more
Correct Answer
Rob Huffman Tue, 10/07/2008 - 05:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ale,
Hope this helps!
Rob
