2621 Router IOS - Need your Urgent HELP
Oct 7th, 2008
Hi All,
I was trying to upgrade my IOS from 12.2-15T to 12.3-26. After reload my router got Crashed. Its not booting up saying software Crashed ...not enf memory. Attaching the Error Log. What should i do next. Can any one help me to load an IOS through Xmodem or any other option please.
Richard Burts Wed, 10/08/2008 - 05:01
Jacob
I would suggest that the first step is to inentify an image that you can run which will fit into the flash and the memory that is available on your router. After you identify an appropriate image you need to get it downloaded and on a server that is accessible from the router.
At that point the links posted by Don may be helpful. I would suggest that if you can get it to work that tftpdnld is a much easier and faster solution than xmodem.
Rick
