SIP/2.0 503 Service Unavailable
Oct 7th, 2008
  • Bronze, 100 points or more
hello,
I have a sip trunk from ccm 5.x to an operator gateway and can make calls to pstn without problems.
The problem is that when i receive a call from the sip gateway via the sip trunk, the call manager sends SIP/2.0 503 Service Unavailable.
NOTE: i receive the full number from the trunk and convert it to the extension via translation-pattern.
Is there any special configuration to solve this issue in inbound calls?
Thank you,
Met.
Overall Rating: 0 (1 ratings)
irisrios Mon, 10/13/2008 - 12:02
  • Silver, 250 points or more
Try to enable inbound/outbound H323 Faststart on the CallManager.
metalium2007 Mon, 10/13/2008 - 12:25
but in the sip trunk config that options does not exist...right?
Thanks!
kinwai Tue, 10/14/2008 - 00:55
what about trying setting "MTP required" to yes?
is it enabled in the first place?
metalium2007 Thu, 10/23/2008 - 04:21
can't anyone point a direction?
Warning: 399 "Routing Failed:..."
Only in Incoming calls from SIP Gateway to CUCM. Outgoing calls are OK.
Met.
metalium2007 Thu, 10/23/2008 - 04:59
Met.
metalium2007 Thu, 10/30/2008 - 13:41
Ok. Problem solved.
Provider provided sip gateway local address and didnt have nat to their public address.
After establishing SIP trunk between CUCM cluster and public sip address, calls work incoming and outgoing.
Thanks for suggestions,
Met.
