10-07-2008 04:21 AM - edited 03-06-2019 01:48 AM
Dear,
Pl explain the cause of the error.
switch: format flash:
Are you sure you want to format "flash:" (all data will be lost) (y/n)?y
Filesystem "flash:" not formatted -- device busy
10-07-2008 05:44 AM
hi
Use commands "erase flash:" to format the flash.
It will erase the complete flash, your device will not boot.
Which is the device you are trying to format. ??
HTH...rate if helpful..
10-07-2008 11:59 PM
Satish,
I am in boor loader console (switch:)
Here even after formatted the flash I could not
copy the image from xmodem.The error as below
switch: copy xmodem: flash:
Begin the Xmodem or Xmodem-1K transfer now...
CCCCCCCCCCBB0BB0xmodem:: I/O error
What could be the issues to solve.
10-19-2008 04:15 AM
Satish,
When i did the xmodem i am getting the below error.
switch: copy xmodem: flash:c3560-advipservicesk9-mz.122-44.SE.bin
CC B B0 .......................................................................
.....999999999999999999999999999999999999999999999999999999999999999999999999999
99999999999999999999999999999999999999999999999999999999999999999999999999999999
9999ï¾flashfs[0]: block_num (-253) not in range between 0 and 252.
flashfs[0]: flashfs_touch, unable to lookup filemap for fileid 1
flashfs[0]: filesystem marked down. Use "fsck" to recover.
flash:c3560-advipservicesk9-mz.122-44.SE.bin: I/O error
